northernmac
Reged: 07/26/07
Loc: ont canada
just curious I think I seen it on here before but what is the running temp of an 865 on a normal day mine runs about 175 I have a temp guage i bought from newspeedmaster
B02S4
Reged: 02/28/08
Loc: USA
Not sure what a "normal day" is for you, however mine tends to run +/- about that as a central point, depending on ambient temperature.
nbsdave
Reged: 10/22/11
Loc: Sarasota, FL
A lot detemines the engine temp. A "normal day" here has been in the mid-90's lately. My 2010 America runs 200 plus a bit after 25-30 miles steady running at 60+, and stays there till I slow down. Couple months ago with temps in the low to mid 80's it was right where yours is.
B02S4
Reged: 02/28/08
Loc: USA
I don't intend to turn this into an oil thread; that said, the oil used does make a difference in engine temps under certain conditions. With M1-15/50 my bike rarely exceed 200F on the hiway, even in 90+ weather, even in traffic.
I noticed that my bike tends to run a bit warmer in really hot weather with Rotella T6-5/40, & I'm not surprised at that.
The_Dog33
Reged: 02/01/07
Loc: NE PA USA
Your carbs are ultra dialed in too and jetting (A/F mixture) effects engine temp too. My bike runs about 180º to 190ºF on an average day running the slab or hard in the twisties. On a really hot day in traffic I have seen about 220ºF and even 230ºF when I was stuck in construction at a stand still almost on a scorching hot day, we started to move shortly after. Good thing since I was about to shut the bike off and sit until it cooled off.
-------------------- I learned all I need to know about life by killing smart people and eating their brains.
some shots of our bikes
northernmac
Reged: 07/26/07
Loc: ont canada
thanks folks all is well then
steve0suprem0
Reged: 09/24/10
Loc: Central Coast, CA
For posterity's sake, a standard day is 59 degrees Fahrenheit and 29.92 inHg.
Edit: at sea level.
Edited by steve0suprem0 (05/28/12 08:29 AM)
B02S4
Reged: 02/28/08
Loc: USA
I took a ride today, air temps were in the high 80's, & just cruising along, oil temps were in the 180 - 190 range.
At 70 F, on my bike oil temps are generally in the 175 range.
edmspeedmaster
Reged: 07/11/11
Loc: Alberta, Canada
anywhere between 15 and 20 C my bike will run around 150 deg if its over 20 and i am in the city it will hover around 175-190
-------------------- 2007 Speedmaster and lovin it!
In Memory of "Friar John" 1967-2012 RIP
mag10
Reged: 01/16/08
Loc: Wisconsin
around 190-210F for normal weather.
-------------------- 05 speedmaster - 904cc, 12:1 JE racing pistons, thunderbike cams, ported and polished head, scepter pipes, blueprinted manifolds, 39mm FCR's
