Technical Forums >> General Tech
Pages: 1
glen
Reged: 01/03/07
Loc: cumbria uk
Led turn signal Problem
      #567015 - 07/07/12 01:03 PM
Just fitted kuryakyn led indicators to my 04 America ,correctly wired up with
Load equaliser. When I pushed switch all four indicators came on together after a lot of head scratching put on original front indicators and They all worked fine. Has anyone had the same problem.is there a fix for this .
Cheers glen
pilgrim
locopony
Reged: 09/01/10
Loc: Texas, Houston
Re: Led turn signal Problem [Re: glen]
      #567033 - 07/07/12 03:15 PM
There is a diode that prevents that from happening. the wiring diagram dont show it, but for both sides to cause that dash light to flash there has to be one.
Bopin in the bad shine, with a bota bag of fried wine.
http://locoponys.com/
B02S4
Reged: 02/28/08
Loc: USA
      #567036 - 07/07/12 03:53 PM
LED Flasher
oldroadie
Reged: 05/05/07
Loc: Alabama USA
Re: Led turn signal Problem [Re: B02S4]
      #567049 - 07/07/12 07:25 PM
Did you replace the dash indicator too? The dash indicator is across the hot leads in the circuit and it might be the culprit due to the impedence difference. When I put a LED in my dash I learned that I had to use two, one polarized each direction. I think there is a proper LED available for that function now.
glen
Reged: 01/03/07
Loc: cumbria uk
Re: Led turn signal Problem [Re: oldroadie]
      #567084 - 07/08/12 08:22 AM
Thanks guys some useful information to be going on
Cheers
pilgrim
glen
Reged: 01/03/07
Loc: cumbria uk
      #567090 - 07/08/12 11:22 AM
Thanks again removed bulb from dash indicator
now work perfectly.
pilgrim
Pages: 1
Extra information
1 registered and 2 anonymous users are browsing this forum.
Moderator:  chy, mert, bennybmn
Print Topic
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Rate this topic
Jump to
Powered by UBB.threads™ 6.5.5
